Salta al contenuto principale
Black and Decker PS1800 Motor Replacement
Cosa ti serve
  1. Black and Decker PS1800 Motor Replacement, Open the Outer Drill Case: passo 1, immagine 1 di 2 Black and Decker PS1800 Motor Replacement, Open the Outer Drill Case: passo 1, immagine 2 di 2
    • Lay the drill on its side, assuring that the screw holes are facing upwards.
    • Remove seven 12 mm screws using a Phillips #00 screwdriver.
  2. Black and Decker PS1800 Motor Replacement: passo 2, immagine 1 di 1
    • Separate the outer drill case to expose the components and switch.
  3. Black and Decker PS1800 Motor Replacement, Disconnect Motor: passo 3, immagine 1 di 3 Black and Decker PS1800 Motor Replacement, Disconnect Motor: passo 3, immagine 2 di 3 Black and Decker PS1800 Motor Replacement, Disconnect Motor: passo 3, immagine 3 di 3
    • Locate the motor at the top left hand corner.
    • Carefully disconnect the red and black wires attached to the motor.
  4. Black and Decker PS1800 Motor Replacement: passo 4, immagine 1 di 1
    • Unscrew the motor from the drill's transmission.
    • Detach the transmission carefully, ensuring that the gears remain intact.
  5. Black and Decker PS1800 Motor Replacement: passo 5, immagine 1 di 2 Black and Decker PS1800 Motor Replacement: passo 5, immagine 2 di 2
    • Remove the motor from the transmission assembly, as pictured.
Conclusione
IUPUI, Team 2-3, Baechle Fall 2016 Membro di IUPUI, Team 2-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G3
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 26
Tutti i Tempi: 1,868
