Salta al contenuto principale
Black and Decker PS1800 Chuck Replacement
Cosa ti serve
  1. Black and Decker PS1800 Chuck Replacement, Chuck: passo 1, immagine 1 di 2 Black and Decker PS1800 Chuck Replacement, Chuck: passo 1, immagine 2 di 2
    • Using the T20 Torx Security screwdriver, take out the 2.3 mm screw inside the chuck.
  2. Black and Decker PS1800 Chuck Replacement: passo 2, immagine 1 di 2 Black and Decker PS1800 Chuck Replacement: passo 2, immagine 2 di 2
    • Set the drill to 'drill mode' and tighten the chuck with the Allen wrench in it.
    • 'Drill mode' is represented by the drill bit symbol
    • Use the Allen wrench to unscrew the chuck by rotating it counter clockwise.
  3. Black and Decker PS1800 Chuck Replacement: passo 3, immagine 1 di 1
    • Remove the chuck completely by unscrewing it in a counter clockwise direction.
Conclusione
David Nawl
Membro da: 10/19/16
279 Reputazione
2 Guide realizzate
IUPUI, Team 2-3, Baechle Fall 2016 Membro di IUPUI, Team 2-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G3
5 Membri
6 Guide realizzate
1Commento della guida
Is the torx screw right or left hand thread
andrewaporter - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 2,856
