Introduzione
This will guide you through the process of removing/replacing the Actuator Fwd/Rev switch on the Black and Decker PS-1800.
Cosa ti serve
Lay the drill on its side, assuring that the screw holes are facing upwards.
Remove seven 12 mm screws using a Phillips #00 screwdriver.
Start separating the outer shell into two parts.
You will find the Fwd/Rev actuator on the right side of the drill, underneath the motor.
Altre 2 persone hanno completato questa guida.
