Salta al contenuto principale
Black and Decker PS1800 Actuator Fwd/Rev Replacement
Cosa ti serve
  1. Black and Decker PS1800  Actuator Fwd/Rev Replacement, Open the Outer Drill Case: passo 1, immagine 1 di 2 Black and Decker PS1800  Actuator Fwd/Rev Replacement, Open the Outer Drill Case: passo 1, immagine 2 di 2
    • Lay the drill on its side, assuring that the screw holes are facing upwards.
    • Remove seven 12 mm screws using a Phillips #00 screwdriver.
  2. Black and Decker PS1800  Actuator Fwd/Rev Replacement: passo 2, immagine 1 di 1
    • Separate the outer drill case to expose the components and switch.
  3. Black and Decker PS1800  Actuator Fwd/Rev Replacement, Actuator Fwd/Rev: passo 3, immagine 1 di 3 Black and Decker PS1800  Actuator Fwd/Rev Replacement, Actuator Fwd/Rev: passo 3, immagine 2 di 3 Black and Decker PS1800  Actuator Fwd/Rev Replacement, Actuator Fwd/Rev: passo 3, immagine 3 di 3
    • Start separating the outer shell into two parts.
    • You will find the Fwd/Rev actuator on the right side of the drill, underneath the motor.
  4. Black and Decker PS1800  Actuator Fwd/Rev Replacement: passo 4, immagine 1 di 3 Black and Decker PS1800  Actuator Fwd/Rev Replacement: passo 4, immagine 2 di 3 Black and Decker PS1800  Actuator Fwd/Rev Replacement: passo 4, immagine 3 di 3
    • Carefully remove the actuator from the drill.
    • Replace the new actuator by inserting it the same way you took it out.
Conclusione
Altre 2 persone hanno completato questa guida.
Hamza Nawaz
Membro da: 11/20/16
247 Reputazione
2 Guide realizzate
IUPUI, Team 2-3, Baechle Fall 2016 Membro di IUPUI, Team 2-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G3
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 17
Tutti i Tempi: 815
