Salta al contenuto principale
Black and Decker LI2000 Orange Casing Replacement
Cosa ti serve
  1. Black and Decker LI2000 Orange Casing Replacement, Orange Casing: passo 1, immagine 1 di 3 Black and Decker LI2000 Orange Casing Replacement, Orange Casing: passo 1, immagine 2 di 3 Black and Decker LI2000 Orange Casing Replacement, Orange Casing: passo 1, immagine 3 di 3
    • Remove the following five screws
    • Three 20 mm Phillips #1 screws
    • One 10 mm #000 Phillips screw
    • One 13 mm Phillips 31 screw
    • When you remove the 13 mm screw, the spring may pop out of the screwdriver. Point the backside of the screwdriver away from your face and others.
  2. Black and Decker LI2000 Orange Casing Replacement: passo 2, immagine 1 di 1
    • Remove the black sticker with recycling information.
  3. Black and Decker LI2000 Orange Casing Replacement: passo 3, immagine 1 di 1
    • Use your fingers or a plastic opening tool to pry the casing apart.
  4. Black and Decker LI2000 Orange Casing Replacement: passo 4, immagine 1 di 1
    • Remove the plastic slider by picking it up off the screwdriver.
    • You may consider leaving half of the casing on the screwdriver to make handling the screwdriver easier.
Conclusione
IUPUI, Team 1-3, Baechle Spring 2016 Membro di IUPUI, Team 1-3, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G3
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 374
