Salta al contenuto principale
Black and Decker LDX172C LED Power Indicator Replacement
Cosa ti serve
  1. Black and Decker LDX172C LED Power Indicator Replacement, LED Power Indicator: passo 1, immagine 1 di 1
    • Before beginning, make sure the motor direction switch is in the neutral position.
    • Place the drill on the work surface with the chuck facing downward. Locate and remove the two #2 X 10mm Phillips screws located right of the motor.
  2. Black and Decker LDX172C LED Power Indicator Replacement: passo 2, immagine 1 di 1
    • Rotate the drill to it's left side - the chuck should be facing rightward. Locate and remove the eight #2 X 5mm Phillips fasteners from the body of the drill.
  3. Black and Decker LDX172C LED Power Indicator Replacement: passo 3, immagine 1 di 1
    • Carefully remove the right half of the body from the drill.
    • The trigger mechanism is spring loaded and may eject from the drill when the body is removed.
    • Locate the LED power indicator located just above the battery pack.
  4. Black and Decker LDX172C LED Power Indicator Replacement: passo 4, immagine 1 di 2 Black and Decker LDX172C LED Power Indicator Replacement: passo 4, immagine 2 di 2
    • The LED is located on a small surface mount circuit board that easily slides out of its mounting location.
    • The LED is removed by freeing the solder joints on the bottom side of the circuit board.
    • Place the new LED through the same holes and re-solder it.
    • To reassemble repeat directions in reverse order.
Conclusione
Casey
Membro da: 02/13/16
260 Reputazione
2 Guide realizzate
IUPUI, Team 3-3, Wilson Spring 2016 Membro di IUPUI, Team 3-3, Wilson Spring 2016
IUPUI-WILSON-S16S3G3
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 12
Tutti i Tempi: 206
