Introduzione
In this guide the user will be able to follow a step by step process on how to open the drill and to check on the motor.
Cosa ti serve
After following the prerequisite guide the interior components can now be accessed.
The motor is the silver cylinder in the top part of the drill.
To remove the motor simply twist as illustrated in the picture.
The way the motor is designed for the LDX 120C is that it is protected inside the aluminum cylinder which works as a magnet.
The inside part of the motor can not be accessed, so you will have to replace the entire motor.
6 Commenti
Great tutorial on how to take it apart. I'm having trouble finding the exact replacement, at least according to the numbers on the motor. Can someone verify what the correct replacement model number is? Also, is it possible to replace it with a brushless motor?
