Salta al contenuto principale
Black and Decker JS660 Power Cord Replacement
Cosa ti serve
  1. Black and Decker JS660 Power Cord Replacement, Housing Disassembly: passo 1, immagine 1 di 2 Black and Decker JS660 Power Cord Replacement, Housing Disassembly: passo 1, immagine 2 di 2
    • Remove the nine torx 15.875mm screws on the front of the jigsaw using a T-15 torx screwdriver.
  2. Black and Decker JS660 Power Cord Replacement: passo 2, immagine 1 di 1
    • By separating the two housing halves, carefully remove the top plate.
  3. Black and Decker JS660 Power Cord Replacement, Power Cord: passo 3, immagine 1 di 1
    • Remove the two 12.7mm phillips head screws holding the power cord in place with a PH2 Phillips head screwdriver.
  4. Black and Decker JS660 Power Cord Replacement: passo 4, immagine 1 di 1
    • Remove the two 6.35mm flat head screws on the trigger with a 2.5 flat head screwdriver to disconnect the white and black cords.
  5. Black and Decker JS660 Power Cord Replacement: passo 5, immagine 1 di 1
    • Gently remove the black and white cord from the trigger assembly.
Conclusione
matt murray
Membro da: 01/27/17
682 Reputazione
6 Guide realizzate
Cal Poly, Team 22-9, Maness Winter 2017 Membro di Cal Poly, Team 22-9, Maness Winter 2017
CPSU-MANESS-W17S22G9
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 770
