Introduzione
This guide will teach the user to easily remove the motor. To do this most components of the saw must first be removed.
Cosa ti serve
Remove the nine torx 15.875mm screws on the front of the jigsaw using a T-15 torx screwdriver.
Being careful to keep all parts together, grab the entire assembly and pull it directly out of the saw.
Remove the two 30.1625mm screws with a T20 torx screwdriver that are holding the gearbox to the housing.
To reassemble your device, follow these instructions in reverse order. Be careful to line up the gearbox before replacement. The corkscrew end of the motor should be fed through each layer of the gearbox.
