Salta al contenuto principale
Black and Decker JS660 Angle Knob Replacement
Cosa ti serve
  1. Black and Decker JS660 Angle Knob Replacement, Base: passo 1, immagine 1 di 2 Black and Decker JS660 Angle Knob Replacement, Base: passo 1, immagine 2 di 2
    • Unscrew the eight screws to open up the jigsaw.
  2. Black and Decker JS660 Angle Knob Replacement: passo 2, immagine 1 di 1
    • Use a screwdriver to remove the first screws securing the base to the jigsaw.
    • Remove the second screw.
    • Remove the base of the jigsaw.
  3. Black and Decker JS660 Angle Knob Replacement: passo 3, immagine 1 di 2 Black and Decker JS660 Angle Knob Replacement: passo 3, immagine 2 di 2
    • With the old jigsaw base off, replace it with the new base by following the steps in the reverse order.
    • Assemble the base on a steady surface.
  4. Black and Decker JS660 Angle Knob Replacement, Angle Knob: passo 4, immagine 1 di 3 Black and Decker JS660 Angle Knob Replacement, Angle Knob: passo 4, immagine 2 di 3 Black and Decker JS660 Angle Knob Replacement, Angle Knob: passo 4, immagine 3 di 3
    • As soon you disassemble the device, you can see the angle knob is not attached to any screws.
    • Remove the angle knob from the device.
Conclusione
USF Tampa, Team 6-2, Eyestone Spring 2016 Membro di USF Tampa, Team 6-2, Eyestone Spring 2016
USFT-EYESTONE-S16S6G2
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 236
