Introduzione
The motor compartment is located on the bottom of the juicer. In this compartment there are many wires. Make sure the machine is off and unplugged before accessing the compartment. Use caution when working with the wires as electric shock can happen.
Cosa ti serve
To replace the motor compartment, first follow the Disassembly Guide here
Use the 2.5 mm Flathead adapter to remove the 13.5 mm screws from the bottom of the juicer. The screw head diameter is 5.2 mm.
Altre 4 persone hanno completato questa guida.
