Salta al contenuto principale
Black and Decker IR02V-T Power Cord Replacement
Cosa ti serve
  1. Black and Decker IR02V-T Power Cord Replacement, Power Cord: passo 1, immagine 1 di 3 Black and Decker IR02V-T Power Cord Replacement, Power Cord: passo 1, immagine 2 di 3 Black and Decker IR02V-T Power Cord Replacement, Power Cord: passo 1, immagine 3 di 3
    • Remove the two silicone covers which encase the screws.
    • Remove both 1 mm screws using a T5 Torx screwdriver.
    • Pry open the plastic cover starting from the top of the iron.
  2. Black and Decker IR02V-T Power Cord Replacement: passo 2, immagine 1 di 3 Black and Decker IR02V-T Power Cord Replacement: passo 2, immagine 2 di 3 Black and Decker IR02V-T Power Cord Replacement: passo 2, immagine 3 di 3
    • Remove both caps from the end of the wire by using pliers.
    • Unfold the metal in the caps using the pliers to release the exposed wire.
    • Remove the two 1 mm screws holding down the wire using a Phillips #00 screwdriver.
    • Once the wires are exposed separate and fold to opposite sides.
  3. Black and Decker IR02V-T Power Cord Replacement: passo 3, immagine 1 di 3 Black and Decker IR02V-T Power Cord Replacement: passo 3, immagine 2 di 3 Black and Decker IR02V-T Power Cord Replacement: passo 3, immagine 3 di 3
    • Remove the old power cord from the iron completely.
    • Insert the new cord through the plastic cover and hole of the iron as demonstrated in the image.
  4. Black and Decker IR02V-T Power Cord Replacement: passo 4, immagine 1 di 3 Black and Decker IR02V-T Power Cord Replacement: passo 4, immagine 2 di 3 Black and Decker IR02V-T Power Cord Replacement: passo 4, immagine 3 di 3
    • Expose about half an inch of wire by removing the silicone that encases it.
    • Tie the new wire into a knot and connect the wires accordingly.
    • Place the caps over the exposed wire and use pliers to tighten the metal to secure the wire.
  5. Black and Decker IR02V-T Power Cord Replacement: passo 5, immagine 1 di 3 Black and Decker IR02V-T Power Cord Replacement: passo 5, immagine 2 di 3 Black and Decker IR02V-T Power Cord Replacement: passo 5, immagine 3 di 3
    • Once the caps are over the wires add the two 1 mm Phillips screws along with the small base plate which secures the wire.
    • When all wires are secure place the plastic cover and screw back in the 1mm Torx screws.
Linea Traguardo
Kevin B
Membro da: 11/10/22
146 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 79
Tutti i Tempi: 1,802
