Salta al contenuto principale
Black and Decker DustBuster 15.6V Nozzle Brush Replacement
Cosa ti serve
  1. Black and Decker DustBuster 15.6V Nozzle Brush Replacement, Nozzle Brush: passo 1, immagine 1 di 1
    • Lift Nozzle Brush until it clicks into fully erect position.
  2. Black and Decker DustBuster 15.6V Nozzle Brush Replacement: passo 2, immagine 1 di 1
    • Apply a gentle, equal pressure outward, to the inside of both brush legs.
  3. Black and Decker DustBuster 15.6V Nozzle Brush Replacement: passo 3, immagine 1 di 1
    • Remove one of the leg prongs from the hole it is inserted into.
  4. Black and Decker DustBuster 15.6V Nozzle Brush Replacement: passo 4, immagine 1 di 1
    • Rotate the free leg forwards or backwards from the hole.
    • This relieves the pressure from the inside of the legs allowing you to freely remove the last leg from its hole.
  5. Black and Decker DustBuster 15.6V Nozzle Brush Replacement: passo 5, immagine 1 di 1
    • Check each leg hole for debris and clear whats needed.
    • Insert a leg of the new brush into the correct hole, so the brush will click into its erect position.
    • Slide the other leg into its respective hole.
Conclusione
Jacob
Membro da: 03/15/17
101 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 354
