Introduzione
This guide will take you through the process of replacing the power cord on the Black and Decker BV2500 Type 4. Without a power cord that works, the device will not turn on.
Cosa ti serve
Using a Phillips #2 screwdriver, remove the six 20 mm screws in the black plastic casing (clamshell).
Using a Phillips #2 screwdriver, remove the ten 20 mm screws in the orange casing.
Use your hands to lift off the side of the orange casing with the screws facing you.
