Salta al contenuto principale
Black and Decker BL3000S Motor Fan Replacement
Cosa ti serve
  1. Black and Decker BL3000S Motor Fan Replacement, Blender Base: passo 1, immagine 1 di 2 Black and Decker BL3000S Motor Fan Replacement, Blender Base: passo 1, immagine 2 di 2
    • Before disassembling the blender base, make sure the blender disconnected from any power outlet.
    • Lift the jar straight up from the base without tilting the jar.
  2. Black and Decker BL3000S Motor Fan Replacement: passo 2, immagine 1 di 1
    • Remove the top three 1/4 inch base screws using a Philip's head screwdriver.
  3. Black and Decker BL3000S Motor Fan Replacement: passo 3, immagine 1 di 2 Black and Decker BL3000S Motor Fan Replacement: passo 3, immagine 2 di 2
    • Remove the two base leg covers next to the power cord using pliers or a flat-head screwdriver.
    • This provides access to the base screws beneath.
  4. Black and Decker BL3000S Motor Fan Replacement: passo 4, immagine 1 di 1
    • Remove the following screws that secure the top and bottom halves of the base.
    • One 1/4 Phillips screw
    • One TA-20 screw
    • Both screwdrivers must have a minimum of a three inch shank (length).
    • Screwdrivers with extenders will not fit down the access holes.
  5. Black and Decker BL3000S Motor Fan Replacement: passo 5, immagine 1 di 1
    • Lift the top half of the base from the bottom half of the base to reveal the internal mechanism.
  6. Black and Decker BL3000S Motor Fan Replacement, Motor Fan: passo 6, immagine 1 di 2 Black and Decker BL3000S Motor Fan Replacement, Motor Fan: passo 6, immagine 2 di 2
    • Using pliers, remove the top nut from the fan and remove the washer.
    • Use a small towel to hold the fan in place. This makes taking off the nut easier to do.
  7. Black and Decker BL3000S Motor Fan Replacement: passo 7, immagine 1 di 1
    • Lift the fan blades from the blender base.
Conclusione
Altre 3 persone hanno completato questa guida.
Andrew
Membro da: 10/04/12
209 Reputazione
4 Guide realizzate
Cal Poly, Team 6-34, Regan Fall 2012 Membro di Cal Poly, Team 6-34, Regan Fall 2012
CPSU-REGAN-F12S6G34
4 Membri
6 Guide realizzate
Un commento
mon mixeur a montre des itincelles et de la fumeé quel étape puis suivre pour le réparer
abdelkarim hassi - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 56
Tutti i Tempi: 4,451
