Salta al contenuto principale
Black and Decker 3-Cup Rice Cooker Circuitry Repair
Cosa ti serve
  1. Black and Decker 3-Cup Rice Cooker Circuitry Repair, Remove the Lid and Bowl: passo 1, immagine 1 di 1
    • Make sure the device is unplugged before beginning disassembly!
    • Lift the lid and bowl from the top of the device.
  2. Black and Decker 3-Cup Rice Cooker Circuitry Repair, Turn the Device Upside-Down: passo 2, immagine 1 di 1
    • Turn the device upside-down, so that the four legs of the device point upwards.
  3. Black and Decker 3-Cup Rice Cooker Circuitry Repair, Remove the Rubber Cushions: passo 3, immagine 1 di 2 Black and Decker 3-Cup Rice Cooker Circuitry Repair, Remove the Rubber Cushions: passo 3, immagine 2 di 2
    • Each of the four legs has a rubber cushion on its bottom. For each cushion, insert a plastic opening tool between the plastic leg and rubber cushion, and pry off the rubber cushion.
  4. Black and Decker 3-Cup Rice Cooker Circuitry Repair, Remove the Spanning Screw: passo 4, immagine 1 di 1
    • Using a spanner screwdriver, remove the one 10mm long 7mm diameter spanner screw from the side of the brass panel.
  5. Black and Decker 3-Cup Rice Cooker Circuitry Repair, Remove the Leg Screws: passo 5, immagine 1 di 1
    • Using a Phillips screwdriver, remove the 10mm long 7mm diameter Phillips-head screws from the inside of all four legs.
    • The smaller leg at the bottom is now loose and not attached to the device. Set it aside.
  6. Black and Decker 3-Cup Rice Cooker Circuitry Repair, Remove the Brass Plate: passo 6, immagine 1 di 1
    • Lift the brass plate off the device and set it aside.
  7. Black and Decker 3-Cup Rice Cooker Circuitry Repair, Color the Wires: passo 7, immagine 1 di 2 Black and Decker 3-Cup Rice Cooker Circuitry Repair, Color the Wires: passo 7, immagine 2 di 2
    • Color coordinating wire groups make it easier to identify the wire groups during reassembly.
    • Inside the device, there are three junctions with wires joined by Phillips-head screws. The first is connected to two wires, and the other two are connected to three wires each.
    • Unscrew the screw at the junction near the opposite side of the device from the front panel.
    • Label each of the two wires at this junction with a single color of tape.
  8. Black and Decker 3-Cup Rice Cooker Circuitry Repair, Label the Second Wire Junction: passo 8, immagine 1 di 2 Black and Decker 3-Cup Rice Cooker Circuitry Repair, Label the Second Wire Junction: passo 8, immagine 2 di 2
    • Unscrew the screw at the junction just clockwise from the button panel.
    • Label the three wires of this junction with tape of a second color.
  9. Black and Decker 3-Cup Rice Cooker Circuitry Repair, Label the Third Wire Junction: passo 9, immagine 1 di 2 Black and Decker 3-Cup Rice Cooker Circuitry Repair, Label the Third Wire Junction: passo 9, immagine 2 di 2
    • Unscrew the screw from the wire junction just behind the front panel.
    • Label the three wires at this junction with a third color of tape.
  10. Black and Decker 3-Cup Rice Cooker Circuitry Repair, Wire Bunch 1: passo 10, immagine 1 di 1
    • If another repair is needed besides to the circuitry, do that repair first. This guide reattaches wires, making other repairs much more difficult.
    • These steps will help you to identify which wires need to connect together in junctions.
    • There are 8 wires, in several groups.
    • Locate one of the wires attached to the power cord that is covered in a thick layer of plastic, and is ziptied to a second, more thinly coated wire.
  11. Black and Decker 3-Cup Rice Cooker Circuitry Repair, Wire Bunch 2: passo 11, immagine 1 di 1
    • Locate two wires that are attached by a ziptie and covered by only a thin layer of plastic.
  12. Black and Decker 3-Cup Rice Cooker Circuitry Repair, Wire Bunch 3: passo 12, immagine 1 di 1
    • Locate another wire that is attached to the power cord and is covered by a thick layer of plastic, and is not ziptied to any other wires.
  13. Black and Decker 3-Cup Rice Cooker Circuitry Repair, 3 Single Wires: passo 13, immagine 1 di 1
    • The remaining three wires are thin and not connected to the power cord or any other wires via ziptie.
Conclusione
Steps 9 - 12 disassemble any part of the device, so no reassembly is needed. If any of the wires were not part of junctions when the device was reassembled, reassemble the device by including the lone wire in the proper junction, as identified in this step.
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 12-1, Forte Fall 2014 Membro di Cal Poly, Team 12-1, Forte Fall 2014
CPSU-FORTE-F14S12G1
5 Membri
7 Guide realizzate
Un commento
The reason why these rice cookers suddenly stop workings is that the in-line cutoff thermal fuse fails and opens the circuit so AC voltage can't make it past the fuse. The thermal fuse is located under the white tubing that the author is holding in step #12. You can order new thermal fuses on eBay pretty cheaply from China. You will need thermal fuse type:
SF169E,172°C
Rated current/voltage:10A/250V
Chet Morton - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 32
Tutti i Tempi: 9,519
