Salta al contenuto principale
Black and Decker 15.6V Filter Replacement
Cosa ti serve
  1. Black and Decker 15.6V  Filter Replacement, Filter Unit Replacement: passo 1, immagine 1 di 2 Black and Decker 15.6V  Filter Replacement, Filter Unit Replacement: passo 1, immagine 2 di 2
    • Disconnect the vacuum's nozzle by pressing the blue buttons on the side of the nozzle.
  2. Black and Decker 15.6V  Filter Replacement: passo 2, immagine 1 di 2 Black and Decker 15.6V  Filter Replacement: passo 2, immagine 2 di 2
    • Disconnect the dustbin from the rest of the vacuum by pressing the blue button on the vacuum's handle.
  3. Black and Decker 15.6V  Filter Replacement: passo 3, immagine 1 di 2 Black and Decker 15.6V  Filter Replacement: passo 3, immagine 2 di 2
    • Remove the entire dustbin.
    • Empty the bin into a trash can if it has debris.
    • Pull the filter unit out from the bottom of the dustbin.
  4. Black and Decker 15.6V  Filter Replacement: passo 4, immagine 1 di 3 Black and Decker 15.6V  Filter Replacement: passo 4, immagine 2 di 3 Black and Decker 15.6V  Filter Replacement: passo 4, immagine 3 di 3
    • With the filter unit in your hand give the dark grey plastic shroud a quarter clockwise turn and remove the shroud exposing the filter.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,645
