Salta al contenuto principale
Bissell SpotClean ProHeat 5207U Water Pump Replacement
Cosa ti serve
  1. Bissell SpotClean ProHeat 5207U Water Pump Replacement, Water Pump: passo 1, immagine 1 di 2 Bissell SpotClean ProHeat 5207U Water Pump Replacement, Water Pump: passo 1, immagine 2 di 2
    • Ensure the device is unplugged.
    • Make sure that you have removed both the clean and dirty water tank so that you can unscrew the proper screws.
    • Remove the marked 19.7 mm screws on the underside of the device using the Phillips #00 screwdriver.
  2. Bissell SpotClean ProHeat 5207U Water Pump Replacement: passo 2, immagine 1 di 3 Bissell SpotClean ProHeat 5207U Water Pump Replacement: passo 2, immagine 2 di 3 Bissell SpotClean ProHeat 5207U Water Pump Replacement: passo 2, immagine 3 di 3
    • Remove the plastic top located where the dirty water tank was previously situated.
    • Using the Phillips #00 screwdriver, unscrew the three 17.2 mm screws.
    • Remove the plastic lip that was previously held by the screws.
  3. Bissell SpotClean ProHeat 5207U Water Pump Replacement: passo 3, immagine 1 di 2 Bissell SpotClean ProHeat 5207U Water Pump Replacement: passo 3, immagine 2 di 2
    • Using pliers, pinch the hose clamp tabs together, then remove the clamp.
    • Remove the water hose from the water pump.
  4. Bissell SpotClean ProHeat 5207U Water Pump Replacement: passo 4, immagine 1 di 2 Bissell SpotClean ProHeat 5207U Water Pump Replacement: passo 4, immagine 2 di 2
    • Remove the green wire by pulling it away from the pump.
    • Be careful not to bend where the wire is plugged into.
  5. Bissell SpotClean ProHeat 5207U Water Pump Replacement: passo 5, immagine 1 di 2 Bissell SpotClean ProHeat 5207U Water Pump Replacement: passo 5, immagine 2 di 2
    • Pull the clear hose away from the pump until it is removed.
  6. Bissell SpotClean ProHeat 5207U Water Pump Replacement: passo 6, immagine 1 di 2 Bissell SpotClean ProHeat 5207U Water Pump Replacement: passo 6, immagine 2 di 2
    • Remove the zip tie from the water pump.
    • Replace the old water pump with the new water pump.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 136
