Salta al contenuto principale
Bissell SpotClean ProHeat 5207U Spraying Mechanism Replacement
Cosa ti serve
  1. Bissell SpotClean ProHeat 5207U Spraying Mechanism Replacement, Spraying Mechanism: passo 1, immagine 1 di 3 Bissell SpotClean ProHeat 5207U Spraying Mechanism Replacement, Spraying Mechanism: passo 1, immagine 2 di 3 Bissell SpotClean ProHeat 5207U Spraying Mechanism Replacement, Spraying Mechanism: passo 1, immagine 3 di 3
    • Place the brush in front of you and make sure that the brushes are rotated towards the ceiling.
    • Separate the brush from the hose by pressing the lever.
  2. Bissell SpotClean ProHeat 5207U Spraying Mechanism Replacement: passo 2, immagine 1 di 3 Bissell SpotClean ProHeat 5207U Spraying Mechanism Replacement: passo 2, immagine 2 di 3 Bissell SpotClean ProHeat 5207U Spraying Mechanism Replacement: passo 2, immagine 3 di 3
    • Using a Phillips screwdriver, unscrew the two 12.8 mm screws on the lever cap.
    • Remove the cap on top of the spring mechanism.
  3. Bissell SpotClean ProHeat 5207U Spraying Mechanism Replacement: passo 3, immagine 1 di 3 Bissell SpotClean ProHeat 5207U Spraying Mechanism Replacement: passo 3, immagine 2 di 3 Bissell SpotClean ProHeat 5207U Spraying Mechanism Replacement: passo 3, immagine 3 di 3
    • Grab the spraying mechanism and separate it from the lever by pulling it back.
    • Rotate the spraying mechanism clockwise to fully separate it.
  4. Bissell SpotClean ProHeat 5207U Spraying Mechanism Replacement: passo 4, immagine 1 di 3 Bissell SpotClean ProHeat 5207U Spraying Mechanism Replacement: passo 4, immagine 2 di 3 Bissell SpotClean ProHeat 5207U Spraying Mechanism Replacement: passo 4, immagine 3 di 3
    • Grab the spring mechanism and pull back to fully loosen it.
  5. Bissell SpotClean ProHeat 5207U Spraying Mechanism Replacement: passo 5, immagine 1 di 3 Bissell SpotClean ProHeat 5207U Spraying Mechanism Replacement: passo 5, immagine 2 di 3 Bissell SpotClean ProHeat 5207U Spraying Mechanism Replacement: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using tweezers, squeeze the hose clamp prongs together to loosen it.
    • As you are squeezing the hose clamp prongs, pull the spraying mechanism out to remove it.
    • Once the spraying mechanism is removed, and squeeze the clamp prongs again and install the new mechanism.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 62
