Salta al contenuto principale
Bissell SmartClean 1605 Roller Brush Replacement
Cosa ti serve
  1. Bissell SmartClean 1605 Roller Brush Replacement, Roller Brush: passo 1, immagine 1 di 1
    • Make sure your device is powered off.
  2. Bissell SmartClean 1605 Roller Brush Replacement: passo 2, immagine 1 di 1
    • Gently flip device over.
  3. Bissell SmartClean 1605 Roller Brush Replacement: passo 3, immagine 1 di 3 Bissell SmartClean 1605 Roller Brush Replacement: passo 3, immagine 2 di 3 Bissell SmartClean 1605 Roller Brush Replacement: passo 3, immagine 3 di 3
    • Remove plastic plate cover to reveal brush roller.
  4. Bissell SmartClean 1605 Roller Brush Replacement: passo 4, immagine 1 di 2 Bissell SmartClean 1605 Roller Brush Replacement: passo 4, immagine 2 di 2
    • Remove brush roller from its slots on either side.
    • Apply pressure to one side and pull the roller out of its opposite slot.
    • It's like taking out a spring loaded toilet paper holder.
Conclusione
Austin Maranville
Membro da: 09/26/17
117 Reputazione
1 Guida realizzata
Cal Poly, Team S7-G4, Banghart Fall 2017 Membro di Cal Poly, Team S7-G4, Banghart Fall 2017
CPSU-BANGHART-F17S7G4
5 Membri
5 Guide realizzate
13 Commenti
What if mine don't feel spring loaded and the brushe seems like it was just wants to fall out
Brian - Replica
I'm having the same issue. The spring is not reloading to the brush just falls out
Rachel -
Same issue with mine. Took it apart and found that the side with spring loaded holder was broken.
Ryan Beaudre - Replica
I am having the same issue it’s like a part is missing for the pin side not the square sides to hold the brush roll in place.
Geoffrey Fraser - Replica
I have the same issue…it seems that the spring part was lost.have anyone of you find a replacement parts?
Mazinger Z - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,024
