Salta al contenuto principale
Bissell Powerglide Cordless Debris Canister Funnel Replacement
Cosa ti serve
  1. Bissell Powerglide Cordless Debris Canister Funnel Replacement, Filter: passo 1, immagine 1 di 3 Bissell Powerglide Cordless Debris Canister Funnel Replacement, Filter: passo 1, immagine 2 di 3 Bissell Powerglide Cordless Debris Canister Funnel Replacement, Filter: passo 1, immagine 3 di 3
    • Remove the gray motor unit by twisting it so that the black triangle moves from the "locked" to the "unlocked" position.
  2. Bissell Powerglide Cordless Debris Canister Funnel Replacement: passo 2, immagine 1 di 1
    • Remove the filter from the dirt canister.
  3. Bissell Powerglide Cordless Debris Canister Funnel Replacement, Debris Canister Funnel: passo 3, immagine 1 di 1
    • Separate the cyclone assembly from the dirt tank by twisting the pieces counterclockwise.
  4. Bissell Powerglide Cordless Debris Canister Funnel Replacement: passo 4, immagine 1 di 1
    • Use a Phillips head screwdriver to remove the three screws from the bottom of the cyclone assembly.
    • Remove the bottom of the assembly.
  5. Bissell Powerglide Cordless Debris Canister Funnel Replacement: passo 5, immagine 1 di 2 Bissell Powerglide Cordless Debris Canister Funnel Replacement: passo 5, immagine 2 di 2
    • Twist the clear plastic capsule with the fins counterclockwise to remove it.
  6. Bissell Powerglide Cordless Debris Canister Funnel Replacement: passo 6, immagine 1 di 1
    • Twist the blue parts counterclockwise with a good amount of force to remove them.
Conclusione
Cal Poly, Team S21-G2, Banghart Winter 2018 Membro di Cal Poly, Team S21-G2, Banghart Winter 2018
CPSU-BANGHART-W18S21G2
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 216
