Salta al contenuto principale
Bissell OptiClean Cyclonic Vacuum Nozzle Replacement
  1. Bissell OptiClean Cyclonic Vacuum Nozzle Replacement, Nozzle: passo 1, immagine 1 di 1
    • Place the vacuum upright and locate the nozzle attachment you want removed.
  2. Bissell OptiClean Cyclonic Vacuum Nozzle Replacement: passo 2, immagine 1 di 2 Bissell OptiClean Cyclonic Vacuum Nozzle Replacement: passo 2, immagine 2 di 2
    • Slide the attachment off of the end of the wand.
  3. Bissell OptiClean Cyclonic Vacuum Nozzle Replacement: passo 3, immagine 1 di 2 Bissell OptiClean Cyclonic Vacuum Nozzle Replacement: passo 3, immagine 2 di 2
    • The brush nozzle attachment has two parts, which can be separated and replaced.
    • The front of the vacuum has slots to hold up to two vacuum attachments. To store, simply place the attachment in the framed slots.
Conclusione
Cal Poly, Team S12-G1, Banghart Winter 2018 Membro di Cal Poly, Team S12-G1, Banghart Winter 2018
CPSU-BANGHART-W18S12G1
5 Membri
5 Guide realizzate
1Commento della guida
- good job team
Austin Marshall - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 315
