Salta al contenuto principale
Bissell OptiClean Cyclonic Vacuum Filter Replacements
Cosa ti serve
  1. Bissell OptiClean Cyclonic Vacuum Filter Replacements, Flex Hose with Handle: passo 1, immagine 1 di 2 Bissell OptiClean Cyclonic Vacuum Filter Replacements, Flex Hose with Handle: passo 1, immagine 2 di 2
    • Grab hold of both the flex hose handle and the extension wand.
    • Pull straight out to detach the handle from the extension wand.
  2. Bissell OptiClean Cyclonic Vacuum Filter Replacements: passo 2, immagine 1 di 1
    • Locate the lock clip on the other end of the flex hose.
  3. Bissell OptiClean Cyclonic Vacuum Filter Replacements: passo 3, immagine 1 di 2 Bissell OptiClean Cyclonic Vacuum Filter Replacements: passo 3, immagine 2 di 2
    • Hold down the lock clip to unlock the flex hose from the vacuum.
    • Remove the flex hose from the vacuum.
  4. Bissell OptiClean Cyclonic Vacuum Filter Replacements, Filters: passo 4, immagine 1 di 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements, Filters: passo 4, immagine 2 di 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements, Filters: passo 4, immagine 3 di 3
    • After removing hose, place vacuum on back and unclip the top compartment.
    • Open the compartment.
    • Pull the dirt collection box out of the vacuum.
  5. Bissell OptiClean Cyclonic Vacuum Filter Replacements: passo 5, immagine 1 di 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: passo 5, immagine 2 di 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: passo 5, immagine 3 di 3
    • Place dirt collection box to the side.
    • Locate the Pre-Motor Filter.
    • Pull the filter out by grabbing the pull tab on top.
  6. Bissell OptiClean Cyclonic Vacuum Filter Replacements: passo 6, immagine 1 di 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: passo 6, immagine 2 di 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: passo 6, immagine 3 di 3
    • Turn vacuum around and locate the filter cover on the bottom.
    • Place fingers in the opening and pull off the filter cover.
    • Place fingers on each tab on the Post-Motor HEPA Media Filter and pull out.
  7. Bissell OptiClean Cyclonic Vacuum Filter Replacements: passo 7, immagine 1 di 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: passo 7, immagine 2 di 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: passo 7, immagine 3 di 3
    • Take filter out to clean or replace.
    • To clean Dirt Collection Box, unlatch lid and take off.
  8. Bissell OptiClean Cyclonic Vacuum Filter Replacements: passo 8, immagine 1 di 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: passo 8, immagine 2 di 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: passo 8, immagine 3 di 3
    • Flip Dirt Collection Box over and locate the push tab.
    • Push the Dirt Cup HEPA Media Filter up to take it off.
    • Picture 3 Shows all the filters taken out of the vacuum.
Conclusione
Cal Poly, Team S12-G1, Banghart Winter 2018 Membro di Cal Poly, Team S12-G1, Banghart Winter 2018
CPSU-BANGHART-W18S12G1
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 13
Tutti i Tempi: 724
