Introduzione
A damaged flex hose on your Bissell OptiClean Cyclonic Vacuum could be a reason that suction power is lost or low. If this is the case, it will be necessary to replace the damaged flex hose with a new one. This guide will teach you how to detach and replace the flex hose with handle on your Bissell OptiClean Cyclonic Vacuum.
Grab hold of both the flex hose handle and the extension wand.
Pull straight out to detach the handle from the extension wand.
Locate the lock clip on the other end of the flex hose.
- color code this step to match the red indicator
-watch out for the lighting (hard shadows)
