Salta al contenuto principale
Bissell CrossWave Cordless Max 2554A Dirty Water Tank Filtration System Replacement
  1. Bissell CrossWave Cordless Max 2554A Dirty Water Tank Filtration System Replacement, Dirty Water Tank Filtration System: passo 1, immagine 1 di 3 Bissell CrossWave Cordless Max 2554A Dirty Water Tank Filtration System Replacement, Dirty Water Tank Filtration System: passo 1, immagine 2 di 3 Bissell CrossWave Cordless Max 2554A Dirty Water Tank Filtration System Replacement, Dirty Water Tank Filtration System: passo 1, immagine 3 di 3
    • Remove the dirty water tank from the main body of the vacuum by pushing down on the blue lever at the top of the dirty water tank.
  2. Bissell CrossWave Cordless Max 2554A Dirty Water Tank Filtration System Replacement: passo 2, immagine 1 di 2 Bissell CrossWave Cordless Max 2554A Dirty Water Tank Filtration System Replacement: passo 2, immagine 2 di 2
    • Grab the filter from both sides and lift it out of the dirty water tank.
  3. Bissell CrossWave Cordless Max 2554A Dirty Water Tank Filtration System Replacement: passo 3, immagine 1 di 2 Bissell CrossWave Cordless Max 2554A Dirty Water Tank Filtration System Replacement: passo 3, immagine 2 di 2
    • Pinch either side of the lid and pull up to separate it from the tank.
  4. Bissell CrossWave Cordless Max 2554A Dirty Water Tank Filtration System Replacement: passo 4, immagine 1 di 2 Bissell CrossWave Cordless Max 2554A Dirty Water Tank Filtration System Replacement: passo 4, immagine 2 di 2
    • Remove the strainer from the device.
    • Removing and replacing this piece regularly ensures that the tank does not become clogged.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 57
