Introduzione
This is a replacement guide for the hose of the Bissell Cleanview Compact Turbo 3437F. The hose transfers debris that the vacuum picks up from the floor to the dirt tank. With a faulty or damaged hose, the vacuum will lose suction and be unable to pick up any debris. This guide shows you how to disconnect both heads of the hose and remove it from the vacuum.
Twist the head of the hose in order to undo the part's lock and pull up to disconnect it.
Conclusione
