Introduzione
Do you have a Bionaire mini tower fan that appears to not be working? It may be due in part to the fan blades spinning the wrong way, which is a very simple fix. If you need to instead replace the fan blades as a whole, just follow the steps that are listed here.
Cosa ti serve
There are 6 screws holding the entire fan together, which need to be removed to access the internals of the fan.
Altre 3 persone hanno completato questa guida.
