Salta al contenuto principale
Bionaire BAP 600 Troubleshooting Outer Shell Replacement
Cosa ti serve
  1. Bionaire BAP 600 Troubleshooting Outer Shell Replacement, Base/Intake: passo 1, immagine 1 di 1
    • Rotate base counterclockwise, supporting top with opposite hand.
  2. Bionaire BAP 600 Troubleshooting Outer Shell Replacement: passo 2, immagine 1 di 1
    • Pull base away from housing exposing air filter.
  3. Bionaire BAP 600 Troubleshooting Outer Shell Replacement, Air Filter: passo 3, immagine 1 di 1
    • Grab the edge of the filter housing and pull the filter away from the rest of the device.
  4. Bionaire BAP 600 Troubleshooting Outer Shell Replacement: passo 4, immagine 1 di 1
    • Gently pull apart each fold of the filter to check for abrasions or other anomalies. Clean with a dust rag if necessary.
  5. Bionaire BAP 600 Troubleshooting Outer Shell Replacement, Outer Shell: passo 5, immagine 1 di 1
    • Remove all 6 screws from the LED housing.
  6. Bionaire BAP 600 Troubleshooting Outer Shell Replacement: passo 6, immagine 1 di 1
    • After the 6 screws are removed, remove the LED housing from the bottom of the device by lifting it off.
  7. Bionaire BAP 600 Troubleshooting Outer Shell Replacement: passo 7, immagine 1 di 1
    • Using two fingers lift the translucent LED cover from the inside. Repeat this step for the second tab.
  8. Bionaire BAP 600 Troubleshooting Outer Shell Replacement: passo 8, immagine 1 di 1
    • After lifting 45 degrees, pull the translucent tab away from thee housing. Repeat this step for the second LED cover.
  9. Bionaire BAP 600 Troubleshooting Outer Shell Replacement: passo 9, immagine 1 di 1
    • Locate the tab about 1 inch below the top vent. Insert a flat tool laterally past the tab and press in toward the center of the device. As the tab is being held down, pull the two halves of the egg apart to keep the shell open.
  10. Bionaire BAP 600 Troubleshooting Outer Shell Replacement: passo 10, immagine 1 di 1
    • Locate the second tab on the back of the device approximately 2 inches above the power cord.
    • Insert the flat tool at a slight angle toward the left of the power cord. Depress the tab and pull the two halves of the shell apart.
  11. Bionaire BAP 600 Troubleshooting Outer Shell Replacement: passo 11, immagine 1 di 1
    • Locate the bottom tab on the front side at the same height as the bottom tab on the back side.
    • Depress the tab using a flat tool at a slight angle and pull the halves apart.
  12. Bionaire BAP 600 Troubleshooting Outer Shell Replacement: passo 12, immagine 1 di 1
    • Locate the last tab about one inch below the top on the front side.
    • Depress the tab using the flat tool at a slight angle and finish pulling the removable half of the shell off.
  13. Bionaire BAP 600 Troubleshooting Outer Shell Replacement: passo 13, immagine 1 di 1
    • Locate the screw housing opposite of the control board, and remove the screw.
  14. Bionaire BAP 600 Troubleshooting Outer Shell Replacement: passo 14, immagine 1 di 1
    • Locate the control board and grab it by the top and bottom firmly. Pull the board straight out being careful not to flex the circuit while removing.
  15. Bionaire BAP 600 Troubleshooting Outer Shell Replacement: passo 15, immagine 1 di 1
    • Locate the screw that was being hidden by the control board and remove it to release the second half of the shell.
  16. Bionaire BAP 600 Troubleshooting Outer Shell Replacement: passo 16, immagine 1 di 1
    • Remove the released half of the shell to finish removing the entire outer shell of the device.
Conclusione
Altre 3 persone hanno completato questa guida.
Nick Miller
Membro da: 10/26/16
167 Reputazione
3 Guide realizzate
IUPUI, Team 4-4, Baechle Fall 2016 Membro di IUPUI, Team 4-4, Baechle Fall 2016
IUPUI-BAECHLE-F16S4G4
5 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 595
