Salta al contenuto principale
Bionaire BAP 600 Air Filter Replacement
  1. Bionaire BAP 600 Air Filter Replacement, Base/Intake: passo 1, immagine 1 di 1
    • Rotate base counterclockwise, supporting top with opposite hand.
  2. Bionaire BAP 600 Air Filter Replacement: passo 2, immagine 1 di 1
    • Pull base away from housing exposing air filter.
  3. Bionaire BAP 600 Air Filter Replacement, Air Filter: passo 3, immagine 1 di 1
    • Grab the edge of the filter housing and pull the filter away from the rest of the device.
  4. Bionaire BAP 600 Air Filter Replacement: passo 4, immagine 1 di 1
    • Gently pull apart each fold of the filter to check for abrasions or other anomalies. Clean with a dust rag if necessary.
Conclusione
Nick Miller
Membro da: 10/26/16
167 Reputazione
3 Guide realizzate
IUPUI, Team 4-4, Baechle Fall 2016 Membro di IUPUI, Team 4-4, Baechle Fall 2016
IUPUI-BAECHLE-F16S4G4
5 Membri
7 Guide realizzate
3 Commenti
Bonjour.merci pour le tutoriel,mais où trouver un filtre…
Frederic Battele - Replica
Where such a filter can be bought? I was in Italy when I order mine from Amazon (UK) but can't find the filter to replace, I damaged mine.
Any idea?
Nuno Filipe - Replica
I been searching for 3 years now. They don't make them. You have to buy a new one. I went to Honeywell and not had a problem.
Blake PS -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 23
Tutti i Tempi: 2,446
