Salta al contenuto principale
Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement
Cosa ti serve
  1. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement, Throttle Cable: passo 1, immagine 1 di 3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement, Throttle Cable: passo 1, immagine 2 di 3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement, Throttle Cable: passo 1, immagine 3 di 3
    • Cut and remove any zip ties securing the throttle cable.
  2. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: passo 2, immagine 1 di 2 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #2 driver to remove the screw securing the lower end of the throttle cable.
  3. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: passo 3, immagine 1 di 2 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: passo 3, immagine 2 di 2
    • Remove the bracket securing the lower end of the throttle cable.
  4. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: passo 4, immagine 1 di 3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: passo 4, immagine 2 di 3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: passo 4, immagine 3 di 3
    • Rotate the lower end of the throttle cable to detach it from the throttle.
  5. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: passo 5, immagine 1 di 3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: passo 5, immagine 2 di 3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: passo 5, immagine 3 di 3
    • When reinstalling the throttle control cable, check to make sure that the throttle control moves the throttle through its full range of motion.
    • If necessary, loosen the screw securing the lower end of the throttle cable and adjust the position of the cable. Re-tighten the screw and check to make sure that the throttle moves through its full range of motion.
  6. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: passo 6, immagine 1 di 2 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: passo 6, immagine 2 di 2
    • Use a 7/16" wrench or deep socket to remove the cap from the throttle control.
  7. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: passo 7, immagine 1 di 2 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: passo 7, immagine 2 di 2
    • Advance the throttle control to expose the gear rack containing the upper end of the throttle cable.
  8. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: passo 8, immagine 1 di 3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: passo 8, immagine 2 di 3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: passo 8, immagine 3 di 3
    • Separate the gear rack from the upper end of the throttle cable.
    • Lift and remove the gear rack from the throttle control.
    • If the gear rack doesn't fully detach, advance the throttle control lever a little farther.
    • Lubricate the gear rack with a bit of lithium grease during reassembly.
  9. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: passo 9, immagine 1 di 3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: passo 9, immagine 2 di 3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: passo 9, immagine 3 di 3
    • Use a 1/2" wrench to unscrew the upper end of the throttle cable from the throttle control.
    • Slide the throttle cable down out of the bottom of the throttle control, and remove the cable.
Conclusione
Altre 2 persone hanno completato questa guida.
Jeff Suovanen
Membro da: 08/06/13
440.074 Reputazione
259 Guide realizzate
iFixit Membro di iFixit
Staff
118 Membri
19.632 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 20
Tutti i Tempi: 2,127
