Introduzione
In this repair you will be using a chain cutting tool to reinsert a pin between two chain links, completing the chain.
Strumenti
Parti
Nessuna parte richiesta.
  1. Rout the chain around the front chain rings and rear derailleur. Pull the ends of the chain together.
    • Rout the chain around the front chain rings and rear derailleur.
    • Pull the ends of the chain together.
  2. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  3. Use the chain cutter tool to press the chain pin back through the chain link. If it is difficult to push it back in, the links are not aligned properly. Realign and try again if this is the case. Caution: Reusing pins in chains can cause the chain to fail.  This is because the pins are press fit into link.  Using a new pin when assembling a chain is recommend for long term use.
    • Use the chain cutter tool to press the chain pin back through the chain link. If it is difficult to push it back in, the links are not aligned properly. Realign and try again if this is the case.
    • Caution: Reusing pins in chains can cause the chain to fail. This is because the pins are press fit into link. Using a new pin when assembling a chain is recommend for long term use.
Linea Traguardo
Altre 3 persone hanno completato questa guida.
aaron thielk
Membro da: 10/10/2010
1.726 Reputazione
5 Guide realizzate
Cal Poly, Team 5-13, Maness Fall 2010 Membro di Cal Poly, Team 5-13, Maness Fall 2010
CPSU-MANESS-F10S5G13
4 Membri
11 Guide realizzate
what do you do if the Chain keeps Falling off when your Riding the Bike an the Chain still rubs against the tire .
Anthony - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 33
Tutti i Tempi: 13,101
