Salta al contenuto principale
Big Trak Battery Replacement
  1. Big Trak Battery Replacement, D Batteries: passo 1, immagine 1 di 3 Big Trak Battery Replacement, D Batteries: passo 1, immagine 2 di 3 Big Trak Battery Replacement, D Batteries: passo 1, immagine 3 di 3
    • Flip over your Big Track
    • Locate the battery cover, and push the cover down, while pushing one of the tabs out of the way
    • Do the same with the other tab
    • Lift the battery cover off
  2. Big Trak Battery Replacement, Battery Removal: passo 2, immagine 1 di 2 Big Trak Battery Replacement, Battery Removal: passo 2, immagine 2 di 2
    • Remove the 4 D batteries from the battery compartment
    • NOTE: There are indicators for which orientation the batteries need to be inserted in
  3. Big Trak Battery Replacement, 9V Battery: passo 3, immagine 1 di 3 Big Trak Battery Replacement, 9V Battery: passo 3, immagine 2 di 3 Big Trak Battery Replacement, 9V Battery: passo 3, immagine 3 di 3
    • Flip the device back over
    • Unscrew the tank hatch
    • Remove the 9V Battery
    • BE CAREFUL NOT TO BREAK THE WIRES FOR THE CONNECTOR
Conclusione
Altre 4 persone hanno completato questa guida.
2Commenti sulla guida
Do you have a photo of the inside of the battery lid?
leigh halford - Replica
Hi. Thanks for the guide, it looked like a connector was missing from mine but, it's the same. There's something loose in mine, have you any help to opening the thing up? As my big Trak that is 40 years old is not working.
Bobby Mahhub - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 32
Tutti i Tempi: 790
