Salta al contenuto principale
Besta Super 5000 Motherboard Replacement
Cosa ti serve
  1. Besta Super 5000 Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the device over so that the barcode is facing upwards.
  2. Besta Super 5000 Motherboard Replacement: passo 2, immagine 1 di 2 Besta Super 5000 Motherboard Replacement: passo 2, immagine 2 di 2
    • Place your fingers on the battery cover arrow and pull the cover down and off the device.
  3. Besta Super 5000 Motherboard Replacement: passo 3, immagine 1 di 1
    • Pull upwards on the battery tab to remove the battery from the device.
  4. Besta Super 5000 Motherboard Replacement, Back Cover: passo 4, immagine 1 di 1
    • Remove the five screws around the edge of the device using a Phillips #0 screwdriver.
  5. Besta Super 5000 Motherboard Replacement: passo 5, immagine 1 di 1
    • Remove the two screws behind the battery using a Phillips #0 screwdriver.
  6. Besta Super 5000 Motherboard Replacement: passo 6, immagine 1 di 2 Besta Super 5000 Motherboard Replacement: passo 6, immagine 2 di 2
    • Potential for device damage: All screws must be removed before you begin this step. Do not forcefully pry apart the device with screws still in it because you may damage it.
    • Gently pry off the backing using an opening tool.
  7. Besta Super 5000 Motherboard Replacement, Motherboard: passo 7, immagine 1 di 1
    • Remove the three silver screws from the black round battery using a Phillips #0 screwdriver.
  8. Besta Super 5000 Motherboard Replacement: passo 8, immagine 1 di 1
    • Remove the five small screws from the motherboard using a Phillips #0 screwdriver.
  9. Besta Super 5000 Motherboard Replacement: passo 9, immagine 1 di 3 Besta Super 5000 Motherboard Replacement: passo 9, immagine 2 di 3 Besta Super 5000 Motherboard Replacement: passo 9, immagine 3 di 3
    • Using a pair of tweezers, pinch the center of the yellow ribbon located in the corner of the device.
    • Potential for device damage: Do not yank or remove the ribbon from the device.
    • Carefully pull the hidden piece of yellow ribbon out from underneath the motherboard.
  10. Besta Super 5000 Motherboard Replacement: passo 10, immagine 1 di 2 Besta Super 5000 Motherboard Replacement: passo 10, immagine 2 di 2
    • Potential for device damage: All screws must be removed before you begin this step. Do not forcefully pry apart the motherboard with screws still in it because you may damage it.
    • Carefully pry off the motherboard with an opening tool.
  11. Besta Super 5000 Motherboard Replacement: passo 11, immagine 1 di 1
    • Take the motherboard out of the body frame.
  12. Besta Super 5000 Motherboard Replacement: passo 12, immagine 1 di 2 Besta Super 5000 Motherboard Replacement: passo 12, immagine 2 di 2
    • Lift the black keyboard mat off of the motherboard.
    • Replace the motherboard.
Conclusione
Jessie
Membro da: 09/30/14
370 Reputazione
3 Guide realizzate
Ohio State, Team 1-5, Buehl Fall 2014 Membro di Ohio State, Team 1-5, Buehl Fall 2014
OSU-BUEHL-F14S1G5
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 12
Tutti i Tempi: 369
