Salta al contenuto principale
Benchmade Griptillian Disassembly
Cosa ti serve
  1. Benchmade Griptillian Disassembly, Close the blade and turn the knife to the side that has the belt clip: passo 1, immagine 1 di 1
    • Be sure to make note of what side the belt clip is on for reassembly.
  2. Benchmade Griptillian Disassembly, Remove screws: passo 2, immagine 1 di 1
    • Use a T6 bit to remove the two screws holding the belt clip.
  3. Benchmade Griptillian Disassembly, Remove T6 Screws: passo 3, immagine 1 di 1
    • Use the T6 bit to remove the four screws holding the handle in place.
  4. Benchmade Griptillian Disassembly, Turn the knife over: passo 4, immagine 1 di 1
    • Turn the knife over and remove one T6 screw.
  5. Benchmade Griptillian Disassembly, Remove the T8 screw: passo 5, immagine 1 di 1
    • Turn the knife over and remove the T8 screw that is going through the hinge.
  6. Benchmade Griptillian Disassembly, Remove the handle: passo 6, immagine 1 di 1
    • Once you've removed the screw, you can remove the handle.
  7. Benchmade Griptillian Disassembly, Drive pin out of the other handle: passo 7, immagine 1 di 1
    • Using the T6 bit, drive the hinge pin out of the other handle.
  8. Benchmade Griptillian Disassembly, Remove the other handle: passo 8, immagine 1 di 1
    • Once you've done this you can remove the other handle.
  9. Benchmade Griptillian Disassembly, Slide the blade out of the frame: passo 9, immagine 1 di 1
    • Be sure to keep both brass washers. Sometimes they will stick to the frame or the blade.
  10. Benchmade Griptillian Disassembly, Sand both sides of copper: passo 10, immagine 1 di 1
    • Using 600 grit sandpaper and a flat surface, rub both sides of the copper washers until there is new material showing.
  11. Benchmade Griptillian Disassembly, Reverse process to re assemble: passo 11, immagine 1 di 1
    • Reverse process to re assemble.
Conclusione
Altre 3 persone hanno completato questa guida.
Spin Modder
Membro da: 07/21/22
256 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 68
Tutti i Tempi: 1,068
