Salta al contenuto principale
BenQ HT1075 Projector Lamp Replacement
Cosa ti serve
  1. BenQ HT1075 Projector Lamp Replacement, Lamp: passo 1, immagine 1 di 1
    • Loosen the 2.5 mm Phillips #1 screw that holds the top assembly in place using a Philips #1 (PH1) screwdriver. This will enable you to lift and slide off the top cover.
    • Fully remove the top cover in order to get to the lamp housing.
  2. BenQ HT1075 Projector Lamp Replacement: passo 2, immagine 1 di 1
    • Carefully peel off the adhesive film covering the lamp housing.
  3. BenQ HT1075 Projector Lamp Replacement: passo 3, immagine 1 di 1
    • Using a Phillips #1 (PH1) screwdriver, loosen and remove the single 2.5 mm Phillips #1 screw that secures the lamp housing to the projector.
  4. BenQ HT1075 Projector Lamp Replacement: passo 4, immagine 1 di 1
    • Remove the lamp from the projector by pulling on the lamp handle.
    • Apply more force on the side opposite of the newly removed screw as you pull the lamp out.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team S6-G1, Banghart Fall 2017 Membro di Cal Poly, Team S6-G1, Banghart Fall 2017
CPSU-BANGHART-F17S6G1
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,573
