Salta al contenuto principale
Bem Wireless HL2739B Speaker Battery Replacement
Cosa ti serve
  1. Bem Wireless HL2739B Speaker Battery Replacement, Speaker Battery: passo 1, immagine 1 di 1
    • Peel the rubber cover back from the corner of the speaker to reveal the screw.
    • Repeat for the three remaining corners.
  2. Bem Wireless HL2739B Speaker Battery Replacement: passo 2, immagine 1 di 3 Bem Wireless HL2739B Speaker Battery Replacement: passo 2, immagine 2 di 3 Bem Wireless HL2739B Speaker Battery Replacement: passo 2, immagine 3 di 3
    • Use the J1 bit attached to the screwdriver to remove the four 10mm screws from the bottom of the speaker.
  3. Bem Wireless HL2739B Speaker Battery Replacement: passo 3, immagine 1 di 1
    • Lift the bottom cover away from the rest of the speaker.
    • There are wires connecting the battery and cover to the rest of the speaker. Be careful when removing the base cover.
    • Using the tweezers, pull the wires from the speaker's internal chip.
    • Be careful not to damage the chip when you remove the wires.
    • It will likely require soldering to reassemble the speaker after this step.
  4. Bem Wireless HL2739B Speaker Battery Replacement: passo 4, immagine 1 di 1
    • Using a plastic opening tool, gently pry the battery from the metal base.
  5. Bem Wireless HL2739B Speaker Battery Replacement: passo 5, immagine 1 di 1
    • Using tweezers, pull the wires from the metal base connection.
Conclusione
Altre 3 persone hanno completato questa guida.
John Donovan
Membro da: 02/28/17
137 Reputazione
1 Guida realizzata
USF Tampa, Team S2-G4, Nance Spring 2017 Membro di USF Tampa, Team S2-G4, Nance Spring 2017
USFT-NANCE-S17S2G4
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,428
