Salta al contenuto principale
Bem Wireless HL2739B Speaker Motherboard Replacement
Cosa ti serve
  1. Bem Wireless HL2739B  Speaker Motherboard Replacement, Speaker Battery: passo 1, immagine 1 di 1
    • Peel the rubber cover back from the corner of the speaker to reveal the screw.
    • Repeat for the three remaining corners.
  2. Bem Wireless HL2739B  Speaker Motherboard Replacement: passo 2, immagine 1 di 3 Bem Wireless HL2739B  Speaker Motherboard Replacement: passo 2, immagine 2 di 3 Bem Wireless HL2739B  Speaker Motherboard Replacement: passo 2, immagine 3 di 3
    • Use the J1 bit attached to the screwdriver to remove the four 10mm screws from the bottom of the speaker.
  3. Bem Wireless HL2739B  Speaker Motherboard Replacement: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Lift the bottom cover away from the rest of the speaker.
    • There are wires connecting the battery and cover to the rest of the speaker. Be careful when removing the base cover.
    • Using the tweezers, pull the wires from the speaker's internal chip.
    • Be careful not to damage the chip when you remove the wires.
    • It will likely require soldering to reassemble the speaker after this step.
  4. Bem Wireless HL2739B  Speaker Motherboard Replacement: passo 4, immagine 1 di 1
    • Using a plastic opening tool, gently pry the battery from the metal base.
  5. Bem Wireless HL2739B  Speaker Motherboard Replacement: passo 5, immagine 1 di 1
    • Using tweezers, pull the wires from the metal base connection.
  6. Bem Wireless HL2739B  Speaker Motherboard Replacement, Speaker Motherboard: passo 6, immagine 1 di 2 Bem Wireless HL2739B  Speaker Motherboard Replacement, Speaker Motherboard: passo 6, immagine 2 di 2
    • Unscrew the four 10mm screws from the motherboard.
  7. Bem Wireless HL2739B  Speaker Motherboard Replacement: passo 7, immagine 1 di 2 Bem Wireless HL2739B  Speaker Motherboard Replacement: passo 7, immagine 2 di 2
    Compra
    • Using tweezers, remove the blue/white and red/black wires from motherboard.
  8. Bem Wireless HL2739B  Speaker Motherboard Replacement: passo 8, immagine 1 di 2 Bem Wireless HL2739B  Speaker Motherboard Replacement: passo 8, immagine 2 di 2
    • Gently re-position the motherboard so you can access the bus wire connected to the speaker.
    • Remove bus wire from the speaker and lift out the motherboard.
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team S2-G4, Nance Spring 2017 Membro di USF Tampa, Team S2-G4, Nance Spring 2017
USFT-NANCE-S17S2G4
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 920
