Introduzione
This guide shows how to completely disassemble the Bella KitchenSmith 2 Slice Toaster 12082. Before beginning the disassembly, make sure that your toaster is not plugged into the wall - you don’t want to get electrocuted while you’re doing your disassembly. While you are doing the disassembly make sure to treat your toaster with respect - the toaster contains a circuit board which could be damaged if you are not careful.
Cosa ti serve
Remove the toaster's handle by firmly grasping it and pulling on it away from the device.
Altre 2 persone hanno completato questa guida.
