Salta al contenuto principale
Bella 4-Slice Toaster Oven Heating Element Replacement
Cosa ti serve
  1. Bella 4-Slice Toaster Oven Heating Element Replacement, Outer Shell: passo 1, immagine 1 di 1
    • Remove five 11.6 mm Phillips #2 screws from the rear of the device.
  2. Bella 4-Slice Toaster Oven Heating Element Replacement: passo 2, immagine 1 di 1
    • Open the front glass door of the toaster oven.
  3. Bella 4-Slice Toaster Oven Heating Element Replacement: passo 3, immagine 1 di 1
    • Locate retaining screw on the upper-middle portion of the door frame.
  4. Bella 4-Slice Toaster Oven Heating Element Replacement: passo 4, immagine 1 di 1
    • Remove one 21.9 mm Phillips #2 retaining screw from upper-middle portion of door frame.
  5. Bella 4-Slice Toaster Oven Heating Element Replacement: passo 5, immagine 1 di 1
    • Flip toaster onto back panel with feet facing forward.
  6. Bella 4-Slice Toaster Oven Heating Element Replacement: passo 6, immagine 1 di 1
    • Use spudger to pry the grey rubber inserts from the black plastic feet.
  7. Bella 4-Slice Toaster Oven Heating Element Replacement: passo 7, immagine 1 di 1
    • Remove four 13.7mm Phillips #2 screws from black plastic feet to separate the cover from the device.
  8. Bella 4-Slice Toaster Oven Heating Element Replacement: passo 8, immagine 1 di 1
    • Lift the black outer cover off of the toaster
  9. Bella 4-Slice Toaster Oven Heating Element Replacement, Heating Element: passo 9, immagine 1 di 1
    • Remove the red wire from the heating element.
  10. Bella 4-Slice Toaster Oven Heating Element Replacement: passo 10, immagine 1 di 1
    • Remove white wire from the opposite side of the heating element.
  11. Bella 4-Slice Toaster Oven Heating Element Replacement: passo 11, immagine 1 di 1
    • Use a metal spudger to unfold the tabs of metal that hold heating element in place.
  12. Bella 4-Slice Toaster Oven Heating Element Replacement: passo 12, immagine 1 di 3 Bella 4-Slice Toaster Oven Heating Element Replacement: passo 12, immagine 2 di 3 Bella 4-Slice Toaster Oven Heating Element Replacement: passo 12, immagine 3 di 3
    • Gently push the heating element from the side with the red wire to remove it from the toaster.
  13. Bella 4-Slice Toaster Oven Heating Element Replacement: passo 13, immagine 1 di 1
    • Repeat steps 1-4 for the second heating element.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 39
Tutti i Tempi: 1,993
