Salta al contenuto principale
Bella 4-Slice Toaster Oven Glass Door Replacement
Cosa ti serve
  1. Bella 4-Slice Toaster Oven Glass Door Replacement, Outer Shell: passo 1, immagine 1 di 1
    • Remove five 11.6 mm Phillips #2 screws from the rear of the device.
  2. Bella 4-Slice Toaster Oven Glass Door Replacement: passo 2, immagine 1 di 1
    • Open the front glass door of the toaster oven.
  3. Bella 4-Slice Toaster Oven Glass Door Replacement: passo 3, immagine 1 di 1
    • Locate retaining screw on the upper-middle portion of the door frame.
  4. Bella 4-Slice Toaster Oven Glass Door Replacement: passo 4, immagine 1 di 1
    • Remove one 21.9 mm Phillips #2 retaining screw from upper-middle portion of door frame.
  5. Bella 4-Slice Toaster Oven Glass Door Replacement: passo 5, immagine 1 di 1
    • Flip toaster onto back panel with feet facing forward.
  6. Bella 4-Slice Toaster Oven Glass Door Replacement: passo 6, immagine 1 di 1
    • Use spudger to pry the grey rubber inserts from the black plastic feet.
  7. Bella 4-Slice Toaster Oven Glass Door Replacement: passo 7, immagine 1 di 1
    • Remove four 13.7mm Phillips #2 screws from black plastic feet to separate the cover from the device.
  8. Bella 4-Slice Toaster Oven Glass Door Replacement: passo 8, immagine 1 di 1
    • Lift the black outer cover off of the toaster
  9. Bella 4-Slice Toaster Oven Glass Door Replacement, Glass Door: passo 9, immagine 1 di 2 Bella 4-Slice Toaster Oven Glass Door Replacement, Glass Door: passo 9, immagine 2 di 2
    • Unhook the black coil springs from back of the toaster on both sides of the device.
  10. Bella 4-Slice Toaster Oven Glass Door Replacement: passo 10, immagine 1 di 1
    • Use the black spudger to gently depress the hinge prongs on the bottom of the door.
  11. Bella 4-Slice Toaster Oven Glass Door Replacement: passo 11, immagine 1 di 2 Bella 4-Slice Toaster Oven Glass Door Replacement: passo 11, immagine 2 di 2
    • Gently slide door away from the device, removing it from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 16
Tutti i Tempi: 886
