Salta al contenuto principale
Bell and Howell DNV16HDZ Lens Assembly Replacement
Cosa ti serve
  1. Bell and Howell DNV16HDZ Lens Assembly Replacement, Lens Assembly: passo 1, immagine 1 di 2 Bell and Howell DNV16HDZ Lens Assembly Replacement, Lens Assembly: passo 1, immagine 2 di 2
    • Remove the five 30mm Phillips #0 screws on the bottom of the camera.
  2. Bell and Howell DNV16HDZ Lens Assembly Replacement: passo 2, immagine 1 di 1
    • Use a plastic opening tool to disconnect the internal hinges that snaps the camera into place.
    • Using a plastic opening tool is important since a metal one will scratch or damage the thin plastic hinges that hold the camera together.
  3. Bell and Howell DNV16HDZ Lens Assembly Replacement: passo 3, immagine 1 di 1
    • It will still be connected by a plastic film. This can also be disconnected by pulling up the white part where it connects to the light circuit board.
Conclusione
Jerry Hadjah
Membro da: 03/04/16
525 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 240
