Salta al contenuto principale
Bell and Howell DNV16HDZ LED Replacement
Cosa ti serve
  1. Bell and Howell DNV16HDZ LED Replacement, Lens Assembly: passo 1, immagine 1 di 2 Bell and Howell DNV16HDZ LED Replacement, Lens Assembly: passo 1, immagine 2 di 2
    • Remove the five 30mm Phillips #0 screws on the bottom of the camera.
  2. Bell and Howell DNV16HDZ LED Replacement: passo 2, immagine 1 di 1
    • Use a plastic opening tool to disconnect the internal hinges that snaps the camera into place.
    • Using a plastic opening tool is important since a metal one will scratch or damage the thin plastic hinges that hold the camera together.
  3. Bell and Howell DNV16HDZ LED Replacement: passo 3, immagine 1 di 1
    • It will still be connected by a plastic film. This can also be disconnected by pulling up the white part where it connects to the light circuit board.
  4. Bell and Howell DNV16HDZ LED Replacement, LED: passo 4, immagine 1 di 1
    • Take out the two 20 mm Phillips #0 screws that attach it to the shutter.
  5. Bell and Howell DNV16HDZ LED Replacement: passo 5, immagine 1 di 3 Bell and Howell DNV16HDZ LED Replacement: passo 5, immagine 2 di 3 Bell and Howell DNV16HDZ LED Replacement: passo 5, immagine 3 di 3
    • The two 30 mm Phillips #0 screws left can be removed to gain access to the circuit board along with the LED.
    • From here we can pop out the LED using the wedge or your fingers if you can manage it.
Conclusione
Donald Desrosier
Membro da: 03/11/16
101 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 296
