Salta al contenuto principale
Bell and Howell DNV16HDZ Front Lens Replacement
Cosa ti serve
  1. Bell and Howell DNV16HDZ Front Lens Replacement, Lens Assembly: passo 1, immagine 1 di 2 Bell and Howell DNV16HDZ Front Lens Replacement, Lens Assembly: passo 1, immagine 2 di 2
    • Remove the five 30mm Phillips #0 screws on the bottom of the camera.
  2. Bell and Howell DNV16HDZ Front Lens Replacement: passo 2, immagine 1 di 1
    • Use a plastic opening tool to disconnect the internal hinges that snaps the camera into place.
    • Using a plastic opening tool is important since a metal one will scratch or damage the thin plastic hinges that hold the camera together.
  3. Bell and Howell DNV16HDZ Front Lens Replacement: passo 3, immagine 1 di 1
    • It will still be connected by a plastic film. This can also be disconnected by pulling up the white part where it connects to the light circuit board.
  4. Bell and Howell DNV16HDZ Front Lens Replacement, Front Lens: passo 4, immagine 1 di 1
    • Take out the two 20 mm screws that attach it to the shutter.
  5. Bell and Howell DNV16HDZ Front Lens Replacement: passo 5, immagine 1 di 1
    • Remove the ten 30 mm Phillips #0 screws from the front lens.
  6. Bell and Howell DNV16HDZ Front Lens Replacement: passo 6, immagine 1 di 1
    • Take the shutter screen parts out of the lens.
    • Now push out the front lens.
    • Slowly take out the shutter screen parts and lens, adding too much force will break them.
Conclusione
Jerry Hadjah
Membro da: 03/04/16
525 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 582
