Introduzione
This guide walks you through how to replace the switch cover on the NetCam.
Cosa ti serve
Use a wrench to loosen up the stand from the back in order to hold the NetCam more comfortably.
Carefully use your fingers to gently pull out the white attachment from the tan colored part.
Use a Phillips #0 screwdriver to take out the two 1.2 mm screws on the board.
On the back of the board pull the switch slowly upward to take it off.
