Salta al contenuto principale
Belkin NetCam HD Microphone Replacement
Cosa ti serve
  1. Belkin NetCam HD Microphone Replacement, Case: passo 1, immagine 1 di 1
    • Use a wrench to loosen up the stand from the back in order to hold the NetCam more comfortably.
  2. Belkin NetCam HD Microphone Replacement: passo 2, immagine 1 di 1
    • Work a plastic opening tool into the seam and pry the face plate away from the back panel.
  3. Belkin NetCam HD Microphone Replacement: passo 3, immagine 1 di 2 Belkin NetCam HD Microphone Replacement: passo 3, immagine 2 di 2
    • Use pressure to separate the covers.
    • When pulling the device apart, separate from the bottom up in order to avoid pulling the wiring at the top apart.
  4. Belkin NetCam HD Microphone Replacement, Microphone: passo 4, immagine 1 di 2 Belkin NetCam HD Microphone Replacement, Microphone: passo 4, immagine 2 di 2
    • Use tweezers to gently pull out the white attachment from the port.
    • Use your fingers to pull out the white attachment from the tan port on the front of the board a little.
  5. Belkin NetCam HD Microphone Replacement: passo 5, immagine 1 di 2 Belkin NetCam HD Microphone Replacement: passo 5, immagine 2 di 2
    • Use a pair of tweezers to wedge between the mic and the rubber guard to remove the mic from the front cover.
    • If the rubber guard comes off with the mic just remove the guard from mic and place back on the front cover.
Conclusione
USF Tampa, Team 3-5, Sullivan Fall 2016 Membro di USF Tampa, Team 3-5, Sullivan Fall 2016
USFT-SULLIVAN-F16S3G5
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 316
