Salta al contenuto principale
Belkin NetCam HD Circuit Board Replacement
Cosa ti serve
  1. Belkin NetCam HD Circuit Board Replacement, Case: passo 1, immagine 1 di 1
    • Use a wrench to loosen up the stand from the back in order to hold the NetCam more comfortably.
  2. Belkin NetCam HD Circuit Board Replacement: passo 2, immagine 1 di 1
    • Work a plastic opening tool into the seam and pry the face plate away from the back panel.
  3. Belkin NetCam HD Circuit Board Replacement: passo 3, immagine 1 di 2 Belkin NetCam HD Circuit Board Replacement: passo 3, immagine 2 di 2
    • Use pressure to separate the covers.
    • When pulling the device apart, separate from the bottom up in order to avoid pulling the wiring at the top apart.
  4. Belkin NetCam HD Circuit Board Replacement, Microphone: passo 4, immagine 1 di 2 Belkin NetCam HD Circuit Board Replacement, Microphone: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to gently pull out the white attachment from the port.
    • Use your fingers to pull out the white attachment from the tan port on the front of the board a little.
  5. Belkin NetCam HD Circuit Board Replacement: passo 5, immagine 1 di 2 Belkin NetCam HD Circuit Board Replacement: passo 5, immagine 2 di 2
    • Use a pair of tweezers to wedge between the mic and the rubber guard to remove the mic from the front cover.
    • If the rubber guard comes off with the mic just remove the guard from mic and place back on the front cover.
  6. Belkin NetCam HD Circuit Board Replacement, Speaker: passo 6, immagine 1 di 2 Belkin NetCam HD Circuit Board Replacement, Speaker: passo 6, immagine 2 di 2
    • Use a Phillips #0 screwdriver to take out the two 1.2 mm screws on the board.
  7. Belkin NetCam HD Circuit Board Replacement: passo 7, immagine 1 di 3 Belkin NetCam HD Circuit Board Replacement: passo 7, immagine 2 di 3 Belkin NetCam HD Circuit Board Replacement: passo 7, immagine 3 di 3
    • With your fingers, pull the circuit board out of the back casing.
    • When pulling the board up be sure to do so carefully so you do not break the cord which is attached on the back side.
  8. Belkin NetCam HD Circuit Board Replacement: passo 8, immagine 1 di 2 Belkin NetCam HD Circuit Board Replacement: passo 8, immagine 2 di 2
    • Gently pull the speaker out of the holder from the back of the cover.
  9. Belkin NetCam HD Circuit Board Replacement: passo 9, immagine 1 di 1
    • The speaker wires are attached with the board. It can be unattached gently by pulling out the white attachment from the port.
  10. Belkin NetCam HD Circuit Board Replacement, Lens Piece: passo 10, immagine 1 di 2 Belkin NetCam HD Circuit Board Replacement, Lens Piece: passo 10, immagine 2 di 2
    • Flip the circuit board to the back side.
    • Fold down the tape with your finger.
    • With the Phillips #0 screwdriver, unscrew the two 1.2 mm screws.
  11. Belkin NetCam HD Circuit Board Replacement: passo 11, immagine 1 di 2 Belkin NetCam HD Circuit Board Replacement: passo 11, immagine 2 di 2
    • Flip the circuit board back to the other side.
    • Unscrew the screw with a Phillips #0 screw driver.
  12. Belkin NetCam HD Circuit Board Replacement: passo 12, immagine 1 di 1
    • Slide the attached piece from the lens holder device.
  13. Belkin NetCam HD Circuit Board Replacement: passo 13, immagine 1 di 2 Belkin NetCam HD Circuit Board Replacement: passo 13, immagine 2 di 2
    Compra
    • Use the tweezers to pull the white attachment out from the port a little.
    • Then, take your fingers and gently pull the white attachment out from the tan port.
  14. Belkin NetCam HD Circuit Board Replacement, Switch Cover: passo 14, immagine 1 di 2 Belkin NetCam HD Circuit Board Replacement, Switch Cover: passo 14, immagine 2 di 2
    • On the back of the board pull the switch slowly upward to take it off.
Conclusione
USF Tampa, Team 3-5, Sullivan Fall 2016 Membro di USF Tampa, Team 3-5, Sullivan Fall 2016
USFT-SULLIVAN-F16S3G5
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 574
