Introduzione
The power PCB is attached to the inside of the back panel and provides access to the power inputs from the exterior of the speaker. This PCB transforms the incoming power to appropriate level for use by the other PCB's in the B212D speaker.
Cosa ti serve
Remove the 8 Phillips screws from the back of the speaker.
There are two silver, 6 mm-long machine screws with two 1/8" inner-diameter washers on the exterior of the metal electronics box; remove these first using a #2 philips screwdriver.
There are five of the same type of machine screw (silver, 6 mm-long) remaining around the metal electronics box's exterior; remove these as well.
Remove the 4, 7/32" long machine screws with a #2 phillips head screwdriver.
Remove the 4 indicated 7/32" long machine screws with a #1 phillips head screwdriver.
Remove the box containing the power PCB.
Altre 6 persone hanno completato questa guida.
13 Commenti
This PCB does not convert electricity, and is rarely what fails. AC leaves this board and gets converted to DC at the rectifier bridge, which is part of the main amp PCB. This main amp board is where 99.9% of issues arise...
Do you know where I can find replacement boards for this speaker? It takes about 20 times of cycling the power button for it to finally come on. Can't seem to find parts anywhere. May not be financially smart to replace the board, but if it's not that expensive, I feel it's worth it.
Justin -
my fuse holder the plastic broke because there is not enough pressure to hold in the fuse and turns on and off
Test esr of all small electrolytic caps eg. 100uf in primary side of ps. In area or 16 and 8 pin dips. Have had this problem cured with caps replaced , often several, small ones in this supply. Especially units that have ran a long time and have heat stressed those elcos. Presently having a problem that is not caps but i suspect theViper22a ic as there is no standby voltage at all and this chip can be “sneaky", sometimes working and sometimes just not firing up.hope you have access to an esr tester as these little caps don't always bloat to show their failure.
Thanks for your detailed explanation. How can I simply replace the fuses? I have new ones but the fuses don’t seem to just screw out to be replaced. Thanks in advance for your prompt response.
ReggieSmith770@gmail.com
I have two of these that are not passing AC power from the first power supply. I assume its AC? I have the schematic for others if you still need. it doesnt list part numbers/types. Anyone know what this should measure on the blue and brown wires? Listed as X7 and X8
I need the speaker input/output board.if anyone knows where I can get one please let me know. Fchazz@gmail.com
Kijk eens op: https://instrumentalparts.com/behringer-...
Hi
Does anyone have a schematic of the P0563 with a parts list? The parts are burned and unidentifiable . Thank You
Hello please some one help to find this part where go fuse Behringer Eurolive B212D Power PCB Replacement Thank you
Eurolive B212d back plate requirement
Ashok Ahlawat - Replica
