Salta al contenuto principale
Beboncool Wireless Switch Pro Controller Buttons Replacement
Cosa ti serve
  1. Beboncool Wireless Switch Pro Controller Buttons Replacement, Motherboard: passo 1, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the seven 5 mm screws from the back of the controller.
  2. Beboncool Wireless Switch Pro Controller Buttons Replacement: passo 2, immagine 1 di 2 Beboncool Wireless Switch Pro Controller Buttons Replacement: passo 2, immagine 2 di 2
    • Gently separate the top and bottom halves of the controller.
  3. Beboncool Wireless Switch Pro Controller Buttons Replacement: passo 3, immagine 1 di 2 Beboncool Wireless Switch Pro Controller Buttons Replacement: passo 3, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove the two 5 mm screws holding the joystick motherboard in place.
  4. Beboncool Wireless Switch Pro Controller Buttons Replacement: passo 4, immagine 1 di 1
    • Carefully move the bumper buttons out of the way.
  5. Beboncool Wireless Switch Pro Controller Buttons Replacement: passo 5, immagine 1 di 2 Beboncool Wireless Switch Pro Controller Buttons Replacement: passo 5, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove the 5 mm screw holding the motherboard in place.
    • Remove the motherboard.
  6. Beboncool Wireless Switch Pro Controller Buttons Replacement, Buttons: passo 6, immagine 1 di 2 Beboncool Wireless Switch Pro Controller Buttons Replacement, Buttons: passo 6, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • To remove the alphabetic buttons, remove the translucent silicone cover.
    • Use tweezers or your fingers to remove the buttons.
    • Pushing a button from below will elevate them enough to easily grab them.
  7. Beboncool Wireless Switch Pro Controller Buttons Replacement: passo 7, immagine 1 di 2 Beboncool Wireless Switch Pro Controller Buttons Replacement: passo 7, immagine 2 di 2
    • To remove the directional buttons, first remove the translucent silicone cover. Then, use tweezers or your fingers to remove the button pad.
    • As with the alphabetic buttons, push on the buttons from below, then grab them.
Conclusione
Tayah Appel
Membro da: 03/27/23
529 Reputazione
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 195
