Salta al contenuto principale
Beats Studio First Generation Motherboard Replacement
Cosa ti serve
  1. Beats Studio First Generation Motherboard Replacement, Removing the outer headband screws.: passo 1, immagine 1 di 1
    • Using the T5 Torx screwdriver, remove the black screws on both sides of the outside of the headband.
    • 4 (2 per side) Torx type T5, 3.5mm long screws.
  2. Beats Studio First Generation Motherboard Replacement, Removing the plastic hinge guards.: passo 2, immagine 1 di 2 Beats Studio First Generation Motherboard Replacement, Removing the plastic hinge guards.: passo 2, immagine 2 di 2
    • Use the plastic opening tool to gently pry the black plastic hinge piece directly away from the headband as shown.
  3. Beats Studio First Generation Motherboard Replacement, Removing the hinge pins.: passo 3, immagine 1 di 1
    • Remove the small metal hinges from their housings. There are a total of 4 hinges, two per side of the headphones.
    • The hinge pins may slide out upon removal of the black hinge piece from the previous step. Be careful not to lose the hinge pins.
  4. Beats Studio First Generation Motherboard Replacement, Removing the metal bands.: passo 4, immagine 1 di 1
    • Using a T5 Torx screwdriver, remove the silver screws from the silver segment of the headband.
    • 4 (2 per side) Torx type T5, 4.0mm long screws.
  5. Beats Studio First Generation Motherboard Replacement, Removing the headband cushion.: passo 5, immagine 1 di 3 Beats Studio First Generation Motherboard Replacement, Removing the headband cushion.: passo 5, immagine 2 di 3 Beats Studio First Generation Motherboard Replacement, Removing the headband cushion.: passo 5, immagine 3 di 3
    • Using the plastic opening tool, gently pry the headband cushion directly away from the plastic portion of the headband as shown. Pry the plastic portion a small amount and then move the opening tool sideways along on the headband. Repeat on both sides until the cushion separates from the top plastic part of the headband.
  6. Beats Studio First Generation Motherboard Replacement, Removing the metal headband support.: passo 6, immagine 1 di 2 Beats Studio First Generation Motherboard Replacement, Removing the metal headband support.: passo 6, immagine 2 di 2
    • Carefully remove the metal band from each of the hinge housings on each side. These should come off quite easily, provided that you have removed the hinges as instructed in step 3.
    • Congratulations, you have completely removed the headband! This will allow for ease of accessibility to the speakers should you choose to delve further into the depths of your headphones.
    • The black wire connecting the two speakers is somewhat fragile! Check that it isn't frayed. If it is frayed, consider repairing it with some electrical tape, splicing it, or replacing it.
  7. Beats Studio First Generation Motherboard Replacement, Removing the ear cushion.: passo 7, immagine 1 di 3 Beats Studio First Generation Motherboard Replacement, Removing the ear cushion.: passo 7, immagine 2 di 3 Beats Studio First Generation Motherboard Replacement, Removing the ear cushion.: passo 7, immagine 3 di 3
    • Pinch the ear cushion between your thumb and forefinger.
    • Be very careful when pulling off the ear cushion, as the material holding the cushion onto the plastic ring can rip easily.
    • Carefully pull the cushion directly away from the earpiece.
    • The cushion will have a thin piece of foam inside of it that may fall out upon removal. Make sure to save this for reassembly.
    • Repeat for the other ear cushion.
  8. Beats Studio First Generation Motherboard Replacement, Removing the plastic ring.: passo 8, immagine 1 di 3 Beats Studio First Generation Motherboard Replacement, Removing the plastic ring.: passo 8, immagine 2 di 3 Beats Studio First Generation Motherboard Replacement, Removing the plastic ring.: passo 8, immagine 3 di 3
    • Use the plastic opening tool to remove the black ring from the speaker. This will allow you to access the screws on the metal ring.
    • Congratulations, you now have access to the rest of the speaker!
    • For reassembly, the black ring cannot snap back into the speaker the way it was disassembled. It must first go inside the black lip of the ear cushion. The black lip is located on the back side of the ear cushion. Please refer to the last two pictures on this step.
    • The black lip is located on the back side of the ear cushion.
  9. Beats Studio First Generation Motherboard Replacement, Removing Metal Ring Earpiece: passo 9, immagine 1 di 2 Beats Studio First Generation Motherboard Replacement, Removing Metal Ring Earpiece: passo 9, immagine 2 di 2
    • Make sure you are working on the speaker that has the label "R" for the right ear. This speaker is the one you must disassemble in order to access the motherboard.
    • Use a 00 Phillips head screwdriver to remove the screws holding down the metal ring.
    • 7 Phillips type 00, 3.9mm long screws.
    • Set aside the metal ring.
  10. Beats Studio First Generation Motherboard Replacement, Removing the Drive (Speaker): passo 10, immagine 1 di 1
    • Using the 0 Phillips head screwdriver, remove the 3 screws holding down the red speaker assembly.
    • 3 Phillips type 0, 8.0mm long screws.
  11. Beats Studio First Generation Motherboard Replacement, Remove Plastic Cover With Foam Top: passo 11, immagine 1 di 2 Beats Studio First Generation Motherboard Replacement, Remove Plastic Cover With Foam Top: passo 11, immagine 2 di 2
    • The screws removed in the previous step held the cover in place so, go ahead and just lift it out!
    • Easy as 1-2-3!
  12. Beats Studio First Generation Motherboard Replacement, Removing Motherboard and Cover: passo 12, immagine 1 di 2 Beats Studio First Generation Motherboard Replacement, Removing Motherboard and Cover: passo 12, immagine 2 di 2
    • Use the 0 Philips screwdriver to remove the two 6.0 mm screws screws that hold the motherboard and cover.
    • Place one hand on the other side ( where the beats logo is) so, that when you take the two screws out, the cover and motherboard don't fall out.
    • 2 Philips type 0, 6.0mm long screws.
  13. Beats Studio First Generation Motherboard Replacement, Remove Motherboard Cover: passo 13, immagine 1 di 2 Beats Studio First Generation Motherboard Replacement, Remove Motherboard Cover: passo 13, immagine 2 di 2
    • Once the screws have been removed from the other side, turn the speaker housing around.
    • Simply lift the cover with the beats logo off.
    • Congratulations! You have uncovered the motherboard!!
  14. Beats Studio First Generation Motherboard Replacement, Remove Power Button Cover: passo 14, immagine 1 di 2 Beats Studio First Generation Motherboard Replacement, Remove Power Button Cover: passo 14, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Locate the black power button switch, then gently remove it with a pair of tweezers.
    • The mute button
    • Power switch.
  15. Beats Studio First Generation Motherboard Replacement, Remove Motherboard From Housing: passo 15, immagine 1 di 1
    • Sometimes the motherboard will just fall out of its housing. If it doesn't, use a plastic opening tool to gently pry or push out.
  16. Beats Studio First Generation Motherboard Replacement, The Motherboard has Landed!: passo 16, immagine 1 di 2 Beats Studio First Generation Motherboard Replacement, The Motherboard has Landed!: passo 16, immagine 2 di 2
    • Congratulations, you now have access to the motherboard!
    • The wires can now be de-soldered and the old motherboard can be replaced with a new one.
    • Before you begin soldering, make sure to mark or label all of the wires so that you remember exactly where they go.
Conclusione
Altre 12 persone hanno completato questa guida.
Oscar
Membro da: 04/15/14
1.175 Reputazione
2 Guide realizzate
Cal Poly, Team 9-18, Regan Spring 2014 Membro di Cal Poly, Team 9-18, Regan Spring 2014
CPSU-REGAN-S14S9G18
4 Membri
13 Guide realizzate
8Commenti sulla guida
Did you know what is the model or tipe of cable? I need to replace it
aaroncruzramirez - Replica
I would love to know as well what kind of cable I need to buy.
I mean the one that is multi colored there, very thin.
Arkymedes -
Where is the Bluetooth Adapter? Is it welded to the mother board? Or is it stand alone with like a flex cable connection? Basically, can the Bluetooth Adapter alone be replaced? Thanks.
Edwin Romero - Replica
There isn’t any Bluetooth. These are WIRED headphones, the model is named “Beats Studio” and these are the FIRST generation.
John Coops -
Do you do beats mixrs electrical wires replacements for the headphones ?
PS MY NAME IS JOEY WILSON and i and 17 teen years old and i was just couries if you can fix the replacement wires for my beats mixrs and they are white and the problems with them are one side works and the other side doesn't work and ut starts to get hot and gets overheat way to easy and they make weird noise so can you please helpme or even tell me what to do to fix my headphones so please send me a response ok thank have a great day .
Joey Wilson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 124
Tutti i Tempi: 30,553
