Introduzione
Through constant usage, the climate, or human bodily fluids, the ear cushions of headphones begin to wear out and get damaged. This guide will go through step-by-step instructions on how to replace your worn out ear pads with new sturdy ones on your Beats Studio 3. You will not need many tools, but you will need patience and understand that rushing this procedure will lead to undesirable results. Lastly, never use force! Although the piece we are replacing today is made up of cushion, it is attached to plastic, metal, and technology that gives you the brilliant sound you love. So be gentle!
Cosa ti serve
Remove the remaining adhesive by making circular movements around the rim of the headset with the provided Isopropyl Alcohol wipe.
There you go! You have completed the guide. You are able to wear the headphones as usual after the 24 hour period. Please dispose of the old ear cushions and clean up your mess!
Altre 9 persone hanno completato questa guida.
2 Commenti
Muchas gracias tanto al autor de la guía de reparación como al traductor de la misma.
Hola!! Donde puedo comprar el recambio de auriculares?? Gracias!!
